<img height="1" width="1" style="display:none" src="https://www.facebook.com/tr?id=1500520490268011&amp;ev=PageView&amp;noscript=1"> cosa fa premium...? | Page 4 | Il Forum di Quattroruote
cosa fa premium...?
fatevi un giro su questa di un mio conoscente collaudatore svizzero e poi mi dite qualcosa se è premium o ......punizione:
Ford Mondeo RS DTM 1.00
By: Questnl
Origin: Extension | Fantasy
Category: Touring
Initial release: 11-Apr-09
Current release: 1.000, on 11-Apr-09
Description
Brand
Ford Mondeo RS DTM
Chassis
Tubular frame construction with steel roof and side panels;
doors, bonnet, wings, boot lid and other panel parts made of carbon fibre reinforced plastic (CFRP);
integrated driver's safety cage and front, rear and side impact structures
Length: 4,872 mm
Width: 1,845 mm
Height: 1,255 mm
Wheelbase: 2,795 mm
Tank: 65 litres
Weight: 1,050 kg (including driver)
Aerodynamics
Aerodynamic modifications on front spoiler
and side panels; smooth under body; rear diffuser;
integral rear spoiler with dual profile
Engine
Ford Cosworth V8
Displacement: 4.0 litres
Cylinder head: 4 valves per cylinder
Cylinder configuration: V8 90°
Maximum power: about 500 hp at 7,500 rpm
Maximum torque: 500 Nm
Air restrictor: 2 x 28 mm diameter
Drive train
Carbon fibre drive shaft; 3-disc carbon fibre clutch activated mechanically by foot pedal; standard 6-speed gearbox with sequential gear shift in transaxle configuration and standard mechanical differential lock; rear-wheel-drive without traction control system
Suspension
Double wishbone suspension with pressure-rod activated spring shock absorbers on front and rear axles
Brakes
Standard carbon braking system without anti-lock braking system (ABS)
Steering
Power-assisted rack and pinion steering
Wheels/tyres
18" aluminium rims, 11" wide on front axle and 12" wide on rear axle; standard tyres, 660mm diameter front and back
Mi è venuta la risposta.
Cosa fa premium?
Re: La disponibilità del cliente a pagare una determinata auto un tot più di quello che vale. Il tot è il premium per la casa che è riuscita nell'impresa. Più è alto il tot più la macchina è premium.
scusa mikuni, per me hai ragione , ma non è da FESSI , o da SUPERFICIALI , o da poco responsabili di quanto valga il danaro, pagare un oggetto piu' di quello che vale , non perchè si è stati imbrogliati, ma perchè si è COSCIENTI di REGALARE quel TOT di soldi in piu'?
Cosa fa premium?
Io correggerei l'espressione "più di quello che vale" con "più della media", visto che anche una Panda da soli 5000 Euro costa molto più di quanto "valga", in termini di materiali + lavoro + ammortamenti, facendo straguadagnare il produttore.
certo che se si pensa a un operaio polacco che guadagna 400 euro e sgobba zitto e muto se no perde il lavoro , e un cassaintegrato italiano che 700 euro comunque li mette in tasca , c'è qualcosa che non torna in termini di sfruttamento e trattamento.....( le auto pero' sono sempre le stesse sia polacche che italiane.....)....
sì è la legge del mercato e del tenore di vita, ma sono una legge e un tenore pervesi.....
BelliCapelli3 ha scritto:
Cosa fa premium?
Vero. Quindi anche la Panda è premium.
Chi spende per quello che gli piace non è nè fesso nè superficiale.
Chi spende perchè crede di diventare più fico girando con una carrozza piuttosto che con un'altra è oltre che fesso e superficiale, pure demente. Se fa le rate poi, è da manicomio :D
Cosa fa premium?
Non direi, anche se amo la panda: perchè tutto quello che si compra costa più di quello che vale: anche il pane ed il latte. Eppure il pane ed il latte non sono certo caviale e champagne.
La chiave è "prezzo rispetto alla media".
è come ad esempio l'acqua minerale : alcuni credono che sia migliore quella marca perchè costa il doppio ed è sempre reclamizzata da "uccellino" o dallo scalatore.....
e invece ce n'è di sconosciuta che è buonissima ,sanissima e levissima , anche non minerale......
Ho votato che attualmente non è da considerarsi Premium ma in futuro...
Questo perchè secondo me ancora i semi non sono del tutto germogliati, ma che dopo le ottime novità sui motori e l'alleanza del Gruppo con Crhysler i nuovi prodotti (SUV, 169 ecc.) aumenteranno al tal punto l'immagine di questo marchio che probabilmente andrà ben oltre il cosiddetto Premium.
sasà65 ha scritto:
Cosa fa premium?
ESATTO!!!!
Più è premium il marchio più è pirla il cliente di quel marchio.
Le cose sono direttamente proporzionate. 8)
Prendete l'esempio dell'Audi e della Skoda, macchine tecnicamente identiche, evidentemente chi acquista Skoda non è pirla a differenza dei fessi che si fanno sbranare per delle Skoda taroccate da Audi. :D
però Audi rispetto a Skoda possiede anche altre carte di prestigio... come le grandi A6 e A8 (certo non confrontabili con la Superb), le sportive TT anche spider, A5 coupé e cabriolet, i vari SUV, la fuoriserie R8... tutti modelli di indubbio prestigio (anche se sempre di opinabile riuscita almeno per qualcuno)...
premium quindi è anche la capacità di offrire una gamma spostata verso "l'alto" e di offrire anche versioni di nicchia sportive o lussuose...
in questo momento Alfa non ha l'ammiraglia (che forse è la cosa più importante per essere veramente una premium completa) però offre comunque delle sportive derivate come l'ancora piacevole Gt e le bellissime Spider e Brera...
un marchio generalista come per esempio la Ford, non può essere quindi considerato pari all'Alfa anche per questo... l'impossibilità di offrire una gamma di prodotti di nicchia o ammiraglie rende difatto (insieme alla storia del marchio, alle caratteristiche di posizionamento sul mercato. ecc) un marchio più o meno premium...
secondo me ti sbagli di grosso: ci sono auto ford-volvo al top di gamma che non hanno nulla da invidiare ad alfa , anzi per me in certe caratteristiche sono pure superiori.
unaploram1979
