<img height="1" width="1" style="display:none" src="https://www.facebook.com/tr?id=1500520490268011&amp;ev=PageView&amp;noscript=1"> menu segreto climatronic...... | Page 2 | Il Forum di Quattroruote
Main channel: 0 - System data
0 Number program
1 Left ERL
2 Skillful ERL
3 Point of job accensione/avvio
4 I recirculate automatic rifle (motor)/I recirculate automatic rifle Bit
5 Heating from active detention
6 Air Quality (7 = fresh air)
7 Deriving
8 Acronym country
9 Sensor zone head
Main channel: 1 - UIF
0 Inner temperature (°C)
1 Surface Temperature (°C) (I think it means external)
2 Temperature piastrine in platinum (°C)
3 Corrector piastrine in platinum (°C)
4 Uif-Sonnenint
5 Corrector radiation (°C)
6 dynamic corrector (°C)
7 OrrettoreC I recirculate (°C)
8 thermal corrector (°C)
9 Compensation ignition (°C)
Main channel: 2 - Sensor radiation SX
0 Radiation not delayed (W/m2)
1 Corrector radiation for regolator temperature (W/m2)
2 Corrector radiation for impeller (W/m2)
3 Value TO
Main Channel: 3 - Sensor radiation DX
3 Value TO
Main Channel: 4 - External Temperature
0 External temperature (°C)
1 Temp. External line CAN (°C)
2 Temperature inhaled air climate (°C)
Main Channel: 5 - Theoretical temperature SX
0 Theoretical Temp. air in escape SX (°C)
1 Theoretical difference between temp. and temp. effective (°C)
2 Value regulation the sx. (½% )
3 Pi-Stell-Max (½%)
4 Defrost SX
Main channel: 6 - Found temperature SX
0 Temp. Found SX (°C)
1 Temp. Feet SX (°C)
2 Temp. Facade SX (°C)
Main channel: 7 - Theoretical temperature DX
0 Theoretical Temp. air in escape DX (°C)
1 Theoretical difference between temp. and temp. effective DX (°C)
2 Values of regulation regolator (½% )
3 Pi-Stell-Max (½% )
4 Defrost
Main channel: 8 - Found temperature DX
0 Found Temp. air in escape DX (°C)
1 Temp. Feet (°C)
2 Temp. Facade (°C)
Main channel:9 - Theoretical temperature evaporator
0 Theoretical temperature evaporator (°C)
1 Theoretical difference between temp. and temp. effective evaporator (°C)
2 Values of regulation evaporator (5mA/Dig)
3 Modality Regolator evaporator (you see under)
Main channel: 10 - Effective temperature evaporator
0 Effective temperature evaporator (°C)
1 Pressure coolant climate (bar)
2 Medium temperature coolant climate (°C)
Main channel:11 - Climate control compressor
0 Power theoretical electrical worker
1 Power effective electrical worker
2 Power electrical worker max
3 Kompressor PWM (0... 200) (Dig)
4 Power electrical worker offset compressor
5 Values power electrical worker
6 Code disinserito compressor (you see system)
Main channel:12 - Climate control impeller
0 Theoretical tension of the electric impeller (V)
1 Manual regulation
2 Code anomaly
3 Reduction impeller (V)
4 Impeller offset (0.1V)
Main channel: 13 - Temperature bocchette air SX
0 Formattato theoretical value (%)
1 Real theoretical value temp. Bocchette sx.(Dig)
2 Confirmation el. temp. Bocchette sx (Dig.)
3 The maximum limit temp. Bocchette sx. (Dig)
4 Limit min. temp. Bocchette sx. (Dig)
Main channel: 14 - Temperature bocchette air DX
1 Real theoretical value temp. Bocchette dx (Dig)
2 Confirmation el. temp. Bocchette dx (Dig)
3 The maximum limit temp. Bocchette dx (Dig)
4 Limit min. temp. Bocchette dx. (Dig)
Main channel: 15 - Piedi/centrale temperature bocchetta
1 Real theoretical value temp. Bocchetta centers them (Dig)
2 Confirmation el. temp. bocchetta centers them (Dig)
3 The maximum limit temp. bocchetta centers them (Dig)
4 Limit min. temp. bocchetta centers them (Dig)
Main channel:16 - Defrost Shovel
1 Theoretical value real Defrost shovel (Dig)
2 Confirmation el. Defrost shovel (Dig)
3 Limit maximum Defrost shovel (Dig)
4 Limit min. Defrost shovel (Dig)
Main channel: 17 - Shovel I recirculate inner
1 Theoretical value real shovel I recirculate (Dig)
2 Confirmation el. shovel I recirculate (Dig)
3 Limit maximum shovel I recirculate (Dig)
4 Limit min. shovel I recirculate (Dig)
Main channel: 18 - Shovel cold air
1 Theoretical value real Shovel cold air (Dig)
2 Confirmation el. Shovel cold air (Dig)
3 Limit maximum Shovel cold air (Dig)
4 Limit min. Shovel cold air (Dig)
Main channel: 19 - Data Motor
0 Vehicle velocity (km/h)
1 Vehicle velocity (Mph)
2 Motor temperature (°C)
3 Engine speed (RPM)
4 Air con compressor speed (RPM)
Main channel: 20 - Data sent by CAN
0 Additional heating (upon request) (1 = on)
1 Confirmation el. PTC (1 = on)
2 Power el. effective PTC
3 % air demanded from radiating climate (%)
4 Relationship % of radiating peak air (%)
5 No performance demanded to the disp. of heating (1=no performance heating)
Main channel: 21 - Ripartitore of air Climate
0 Defrost (%)
1 Facade (%)
2 Feet (%)
3 Bocchetta areazione (%)
4 I recirculate fresh air/cleaned up (+ bocchetta...) (%)
5 Appraisal sensor (%)
Main channel: 22 - Data timer
0 Period of pause (min)
1 Motor operating time (sec)
2 Operating time with inserted key (Sec)
Main channel: 23 - Special channel
0 Sensor inner lighting system (Dig)
1 Air quality sensor
Main channel:24 - Version software
0 Development state
1 Software version
2 Type SW
3 Keep Frozen (0/1 = Values of refrigeration come maintained ad.eccezione.della Diagnosis )
4 Version K Matrix
5 EEP- Testflags
6 It codifies Vag (2)
Main channel: 25 - Test channels
1 - 9
Main channel: 26 - Parameters for surveys on crystals
0 Delay (sec)
1 Passo/udm (digit)
2 The minimal limit (digit)
3 Limit max. (digit)
4 Passo/udm on HellaKit
Main channel: 26 - Bocchetta direct areazione
1 Theoretical value real Bocchetta direct areazione (Dig.)
2 Confirmation el. Bocchetta direct areazione (Dig.)
3 Limit max. Bocchetta direct areazione (Dig.)
4 Limit min. Bocchetta direct areazione (Dig.)
Main channel: 28 - Umidita
0 Theoretical Umidita (%)
1 Relative Umidita on temperature UIF (%)
2 Temp. Crystals WSS (°C)
3 Temperature condensation point (°C)
4 Difference temperature of the melting point (°C)
Main channel: 29 - Crude values umidita
0 Temp. Crystals, corrected (°C)
1 Temp. Crystals, not corrected (°C)
2 Sensor umidita (%)
3 Temperature sensor (°C)
4 Temperature condensation point (test measure) (°C)
5 Code anomaly
Main channel: 30 - Values indicated to you umidita
0 Value sensor termofilo (Dig.)
1 Temperature rif. termofilo (Dig.)
2 Periodic duration umidita (10 (to the power of -4) sec)
3 Temp. Reference umidita (Dig.)
4 Umidita Rel. on the sensor (%)
5 Temperature sensor umidita (°C)
6 Temperature crystals (not corrected) (°C).
la lista qui sopra è stata fatta per il climatronic della golf V che non del tutto identico al nostro, quindi potrebb esserci qualche differenza.
Per questo avrei voluto fare qualche prova in più prima.
E' evidente che per le octy dal my2009 in poi tutto questo non è valido: è cambiato il climatronic....
5 stelle per l'impegno!! sarebbe stato più facile da usare se avessereo replicato le informazioni anche sul display della radio, come avviene per le regolazioni del clima.. almeno io le ho attivate.. non è che se si è attivata la visualizzazione dei comandi del clima sulla radio appaiono anche tutte queste info?
No, le informazioni sono sempre sui display del clima. Del resto è un menu di servizio a uso e consumo del personale tecnico e non certo per gli utenti.....non deve essere user friendly.
E' interessante l'indicazione della velocità: sembrerebbe piuttosto precisa.
Scarta di qualche km/h in difetto rispetto al tacho ed è direi il linea con quella che fornisce il tomtom.
Peccato che non ci sia l'indicazione della temperatura dell'olio, dellatensione dell'impianto elettrico e....che ne so.....la pressione del turbo.
In fin dei conti sembrerebbero tutti parametri utili alla gestione del climatizzatore e quelli che ho indicato io non c'entrerebbero per nulla.
chissa' se tra qualche anno avremo un vero compiuter di bordo,dove si puo' visualizzare qualunque cosa,
o spariranno anche i maxidot??
visto che la tendenza di molti,(non parlo naturalmente di noi)
e' di usare la macchina fino quando girano le ruote o anche fino quando, si rimane senza benzina :D :D
gia' su molte auto e' sparito l indicatore dell acqua,dell olio,del turbo,
ma il prezzo del veicolo non e' certo diminuito :?
Temo che certi strumenti siano destinati a sparire..
Sono utili se si ha un minimo d'idea di cosa c'è sotto il cofano di una vettura. Ormai i prodotti non nascono a caso, ma analizzando a fondo conoscenze, esigenze e velleità del target dei acquirenti potenziali a cui essi si rivolgono. Credo che questi indicatori siano scomparsi perchè il cliente medio, (sempre attento alla scelta del testimonial che pubblicizza l'auto, all'abbinamento dei tessuti e delle plance in tinta con gli specchi retrovisori ecc..), non sapeva cosa farne.... :D
Ho appena provato il mesu nr. 19 (indicazione della velocità). Molto interessante ed anche utile. complimenti. Five stars (ovvero 5 stelle)
rosberg ha scritto:
Interessante....peccato che sono in inglese e molte cose nemmeno so cosa siano....
Comunque bravo! 5 stelle
ho travato questi credo siano gli stessi codici ma in italiano:
0 Dati del sistema 0
1 ERL sinistra
2 ERL destra
3 Punto di lavoro accensione/avvio
4 Ricircolo automatico (motore) / Ricircolo automatico Bit
5 Riscaldamento da fermo attivo
6 Qualità aria
7 Derivato
8 Sigla paese
9 Sensore zona testa
1 UIF 0
1 Temperatura superficie
2 Temperatura piastrine in platino (?)
3 Correttore piastrine in platino (?)
4 Uif-Sonnenint (?)
5 Correttore irraggiamento (?)
6 correttore dinamico
7 Correttore ricircolo
8 correttore termico
9 Compensazione accensione UIF
2 Sensore irraggiamento SX 0
1 Correttore irraggiamento per regolatore temperatura
2 Correttore irraggiamento per ventola
3 Valore AD
3 Sensore irraggiamento DX 0
3 Valore AD
4 Temperatura Esterna 0
1 Temp. Esterna linea CAN
2 Temperatura aria aspirata clima
5 Temperatura teorica SX 0
1 Differenza tra temp. teorica e temp. effettiva
2 Valore regolazione I sx.
3 Pi-Stell-Max (?)
4 Defrost SX
6 Temperatura rilevata SX 0
1 Temp. Piedi SX
2 Temp. Frontale SX
7 Temperatura teorica DX 0
1 Differenza tra temp. teorica e temp. effettiva DX
2 Valori di regolazione regolatore
3 Pi-Stell-Max (?)
4 Defrost DX
8 Temperatura rilevata DX 0
1 Temp. Piedi
2 Temp. Frontale
9 Temperatura evaporatore teorica 0
1 Differenza tra temp. teorica e temp. effettiva evaporatore
2 Valori di regolazione evaporatore
3 Modalità Regolatore evaporatore (vedi sotto)
10 Temperatura evaporatore effettiva 0
1 Pressione liquido refrigerante clima
2 Temperatura media liquido refrigerante clima
11 Compressore clima 0
1 Potenza elettrica effettiva
2 Potenza elettrica max
3 Kompressor PWM (0...200)
4 Potenza elettrica compressore offset
5
6
12 Ventola clima 0
1 Regolazione manuale
2 Codice anomalia
3 Riduzione ventola
4 Offset ventola (di qui in avanti modalità automatica)
13 Temperatura bocchette aria SX 0
1 Valore teorico reale temp. Bocchette sx.
2 Conferma el. temp. Bocchette sx.
3 Limite massimo temp. Bocchette sx.
4 Limite min. temp. Bocchette sx.
14 Temperatura bocchette aria DX 0
1 Valore teorico reale temp. Bocchette dx
2 Conferma el. temp. Bocchette dx
3 Limite massimo temp. Bocchette dx.
4 Limite min. temp. Bocchette dx.
15 Temperatura bocchetta piedi/centrale 0
1 Valore teorico reale temp. Bocchetta centrale
2 Conferma el. temp. bocchetta centrale
3 Limite massimo temp. bocchetta centrale
4 Limite min. temp. bocchetta centrale
16 Paletta Defrost 0
1 Valore teorico reale paletta Defrost
2 Conferma el. paletta Defrost
3 Limite massimo paletta Defrost
4 Limite min. paletta Defrost
17 Paletta ricircolo interno 0
1 Valore teorico reale paletta ricircolo
2 Conferma el. paletta ricircolo
3 Limite massimo paletta ricircolo
4 Limite min. paletta ricircolo
18 Paletta aria fredda 0
1 Valore teorico reale Paletta aria fredda
2 Conferma el. Paletta aria fredda
3 Limite massimo Paletta aria fredda
4 Limite min. Paletta aria fredda
19 Dati Motore 0
1 Temperatura motore
2 Giri motore
3 Giri compressore clima
20 Dati inviati sulla CAN 0
1 Conferma el. PTC
2 Potenza el. effettiva PTC
3 % aria richiesta da radiatore clima
4 Rapporto % di picco aria radiatore
5 Nessuna prestazione richiesta al disp. di riscaldamento
21 Ripartitore di aria Clima 0
1 Frontale
2 Piedi
4 Ricircolo aria fresca / pulita (+ bocchetta ...?)
5 Valutazione sensore
22 Dati timer 0
1 Tempo di funzionamento motore
2 Tempo di funzionamento con chiave inserita
23 Canale speciale 0
1 Sensore qualità aria
24 Versione software 0
1 Versione software
2 Tipo SW
3 Keep Frozen
4 Versione K Matrix
5 EEP- Testflags
6 Codifica Vag (?) 2
25 Canali di prova 0
1 Canale1
2 Canale2
3 Canale3
4 Canale4
5 Canale5
6 Canale6
7 Canale7
8 Canale8
9 Canale9
26 Parametri per rilevamenti sui cristalli 0
1 Passo/udm (?)
2 Limite minimo
3 Limite max.
4 Passo/udm su HellaKit (?)
27 Bocchetta areazione diretta 0
1 Valore teorico reale Bocchetta areazione diretta
2 Conferma el. Bocchetta areazione diretta
3 Limite max. Bocchetta areazione diretta
4 Limite min. Bocchetta areazione diretta
28 Umidita 0
1 Umidita? relativa sulla temperatura UIF?
2 Temp. Cristalli WSS
3 Temperatura punto di condensazione
4 Differenza temperatura del punto di fusione
29 Valori grezzi umidità 0
1 Temp. Cristalli, non corretta
2 Sensore umidità
3 Temperatura sensore
4 Temperatura punto di condensazione (misura di prova)
5 Codice anomalia
30 Valori indicativi umidità 0
1 Temperatura rif. termofilo
2 Durata periodica umidità
3 Temp. Riferimento umidità
4 Umidità Rel. sul sensore
5 Temperatura sensore umidità
6 Temperatura cristalli (non corretta)
ciao e buon anno a tutti
Nel frattempo ho trovato anch'io un elenco tradotto, ma l'ho "cippato" a un altro forum, è un file .xls riconoscibilissimo e non volevo pubblicarlo sfacciatamente per rispetto di chi l'ha fatto.
In ogni caso ora c'è il tuo...
ho pubblicato questo elenco in italiano dicendo di averlo trovato ... anche se qualche modifica (se pur minima) è stata da me inserita,
comunque pubblicando spero di non aver mancato di rispetto a nessuno
se cosi non fosse chiedo venia.
ciao
Utente_4074716402
