<img height="1" width="1" style="display:none" src="https://www.facebook.com/tr?id=1500520490268011&amp;ev=PageView&amp;noscript=1"> Ford Mondeo Titanium S | Page 9 | Il Forum di Quattroruote
No... le foto da locandina sono tamarre.... :D
Nera, ce l'ho adesso e... mai piu!!!
Comunque abbi fede... wagon naturalmente, con me dovrà soffrire...
cangio in germania questa la trovi:
BlobServer
QUESTA PERO' è PER POCHI:
Ford Mondeo RS DTM 1.00
By: Questnl
Origin: Extension | Fantasy
Category: Touring
Initial release: 11-Apr-09
Current release: 1.000, on 11-Apr-09
Description
Brand
Ford Mondeo RS DTM
Chassis
Tubular frame construction with steel roof and side panels;
doors, bonnet, wings, boot lid and other panel parts made of carbon fibre reinforced plastic (CFRP);
integrated driver's safety cage and front, rear and side impact structures
Length: 4,872 mm
Width: 1,845 mm
Height: 1,255 mm
Wheelbase: 2,795 mm
Tank: 65 litres
Weight: 1,050 kg (including driver)
Aerodynamics
Aerodynamic modifications on front spoiler
and side panels; smooth under body; rear diffuser;
integral rear spoiler with dual profile
Engine
Ford Cosworth V8
Displacement: 4.0 litres
Cylinder head: 4 valves per cylinder
Cylinder configuration: V8 90°
Maximum power: about 500 hp at 7,500 rpm
Maximum torque: 500 Nm
Air restrictor: 2 x 28 mm diameter
Drive train
Carbon fibre drive shaft; 3-disc carbon fibre clutch activated mechanically by foot pedal; standard 6-speed gearbox with sequential gear shift in transaxle configuration and standard mechanical differential lock; rear-wheel-drive without traction control system
Suspension
Double wishbone suspension with pressure-rod activated spring shock absorbers on front and rear axles
Brakes
Standard carbon braking system without anti-lock braking system (ABS)
Steering
Power-assisted rack and pinion steering
Wheels/tyres
18" aluminium rims, 11" wide on front axle and 12" wide on rear axle; standard tyres, 660mm diameter front and back
La foto della mia mondeo 2.2 TDCI S un giorno prima della consegna.
http://alerts.quattroruote.it/reporter_digitali/zoomfoto.cfm?ID=201147
poi i soliti dicono che le "premium" sono altre....... che ridere!
L'ho gia chiesto in precedenza, mi aiutate a capire per cortesia?
Finora ho letto di 2 Titanium S, una berlina di Ezio e una wagon di Mondeone.
Mi dite per cortesia di dove siete voi due, attualmente UNICI possessori, visto che girando sulle strade di tutti i giorni non ne ho mai vista una?
Ezio, di dove sei?
Mondeone, di dove sei?
ciao
Ezio, di dove sei?
ciao
Io sono di Milano
Ezio, di dove sei?
ciao
Io sono di Milano
Bene, un amico mi aveva accennato ad una nera come la tua vista sul lago Maggiore, magari eri tu...
prodadcima1981
