<img height="1" width="1" style="display:none" src="https://www.facebook.com/tr?id=1500520490268011&amp;ev=PageView&amp;noscript=1"> Maserati Ghibli III | Page 18 | Il Forum di Quattroruote
Maserati Ghibli III
Beh, il diesel sulle auto di prestigio e sportive è stato "sdoganato" dalla Porsche.
Però devo dire che anche io, se avessi la disponibilità finanziaria per acquistare e soprattutto mantenere una Maserati Ghibli, forse farei un piccolo sforzo in più e la prenderei a benzina. Sempre Maserati è.
Inoltre penso che il motore diesel sia stato deliberato pensando poco al mercato italiano, che costituisce oggi il 2-3% delle vendite Maserati. Evidentemente è un motore molto richiesto anche all'estero, anche per i più bassi costi di gestione.
Qui sembrerebbe uscire relativamente a pezzi.
http://www.autocar.co.uk/car-review/maserati/ghibli
Alcuni passaggi salienti:
"In the meantime, take a moment to ponder the pedigree of this ?new? diesel engine. Said to be developed by Maserati under the watchful eye of Ferrari engine man Paulo Martinelli, it is nevertheless based on the same 3.0-litre V6 used by the Jeep Grand Cherokee, even though it is built by VM Motori.
And while no one at Maserati is making the connection, we cannot help but notice that not only is its 2987cc capacity identical to that of Mercedes? current 3.0-litre V6 diesel, but its bore and stroke are also the same.
That?s the Mercedes owned by Daimler that also used to own Chrysler which still owns Jeep, both of which are now owned by Fiat, which also owns Maserati. Engineering multiculturalism at its finest."
" Adequate? is not a word you want to hear in any description of a Maserati, but there seems none better to describe the performance of the diesel Ghibli in both subjective and objective terms.
Its acceleration would be entirely unremarkable for the class were it to wear a BMW or Mercedes badge. Indeed, it?s slower to 100mph than both the CLS350 CDI and a BMW 530d, let alone the 535d which is its closer rival, and it?s no quicker than an Audi A7 3.0 TDI. Is 0-60mph in 6.5sec and a 0-100mph time of 17.2sec acceptable for a Maserati? We?d say yes, just, but a Volkswagen Golf GTI is about as quick to both targets."
"Sadly, the Ghibli is no better at losing speed than it is at gaining it. At a socking 2040kg on our scales, our diesel test car was more than 200kg heavier than Maserati?s figures suggest, causing brake fade on the test track and, on the road, merely the sense of a car with sufficient braking potential for the performance but no more. The car also took a long time to stop in the wet."
"Despite a standard limited-slip differential, traction is surprisingly limited. On the move, grip levels degrade from excellent to unimpressive, and if you throw in some typical British B-road gremlins ? tightening radii, surface and camber changes ? the Ghibli can suddenly feel large, heavy and a little ponderous.
The ride is problematic. We don?t think customers will expect a Maserati to ride like a Mercedes, but even with this taken this into account, the Ghibli is still too intolerant of high-frequency bumps and, especially, our ubiquitous potholes, which jolt the structure sufficiently to suggest there?s too much unsprung mass hanging off each corner of the car.
Overall, the Ghibli is not as refined as we?d hoped. The diesel motor is too audible when under load and, at least on 20in rims, there is far too much road noise on coarse surfaces."
"From the way it looks to the sense of occasion it imparts, this car is special.
The suspension needs to be sorted out if it's to compete with E-class Mercedes
But more than any other Maserati, the Ghibli must work as a device for doing a job, in a segment where the standard is through the roof.
And here, the Ghibli is second best in too many areas. The car?s ride, refinement and ease of use are all notable for their mediocrity ? and the diesel lags behind its rivals in terms of performance, too.
The result is not a poor car. It still charms and it?s the most rounded Maserati ever created. But the sense it leaves is not of how good it is, but of how much better it could and should have been.
Rivals like the BMW 5-series, Jaguar XF and Mercedes-Benz CLS remains the more preferable option ? for now."
Si, una batosta (per la diesel). Gli inglesi spesso non sono molto teneri con le auto italiane. Però la versione a benzina trova molti estimatori. Oltre Quattroruote.it, per esempio qui:
http://www.motori.it/test-drive/17396/maserati-ghibli-30-v6-s-q4-prova-su-strada.html
La Ghibli comunque si sta dimostrando un successo mondiale e, per la prima volta per Maserati dopo molti anni, l'Italia è uno dei principali mercati, il 1° in Europa e il 3° nel mondo:
http://www.quattroruote.it/news/mercato/2014/04/04/maserati_ghibli_l_italia_il_terzo_mercato_mondiale_.html
Maxetto883 ha scritto:
Non li facevo così invidiosi gli inglesi. :D
Maserati fa una balenottera, gli inglesi se ne accorgono e lo dicono ed il problema per Maxetto sta negli inglesi invidiosi.
Che tristezza Maxetto...
Dare dell'invidioso ad un inglese che ti consiglia un prodotto tedesco invece di uno italiano fa effettivamente ridere, ma credo non nel senso che intendi tu. Comicità involontaria.
Saranno sicuramente al soldo dei tedeschi pure loro...secondo i nostri prodi...
Vedo che ci vuole poco a scatenare subito le risposte degli stessi di sempre, anche reincarnati.
Maserati ha già fatto grandi passi in avanti rispetto al passato ed è ad un passo dai tedeschi e anglo-indiani.
Il successo di cui parla Pilota lo conferma.
State sereni e non rattristatevi.
loiwideworl1985
