<img height="1" width="1" style="display:none" src="https://www.facebook.com/tr?id=1500520490268011&amp;ev=PageView&amp;noscript=1"> &#34;sgamata&#34; la FIA | Il Forum di Quattroruote
ecco la trascrizione della comunicazione radio tra Hamilton e la squadra:
-Transcript of McLaren radio transmission
Thursday, April 2nd 2009, 13:14 GMT
Transcript of the radio transmission between Lewis Hamilton and McLaren during the Australian Grand Prix:
Team: OK Lewis, you should need to make sure your delta is positive over the safety car line. After the safety car line the delta doesn't matter but no overtaking. No overtaking.
Lewis Hamilton: The Toyota went off in a line at the second corner, ..., is this OK?
Team: Understood, Lewis. We'll confirm and get back to you.
LH: He was off the track. He went wide.
Team: Lewis, you need to allow the Toyota through. Allow the Toyota through now.
LH: OK.
LH: He's slowed right down in front of me.
Team: OK, Lewis. Stay ahead for the time being. Stay ahead. We will get back to you. We are talking to Charlie.
LH: I let him past already.
Team: OK, Lewis. That's fine. That's fine. Hold position. Hold position.
LH: Tell Charlie I already overtook him. I just let him past.
Team: I understand Lewis. We are checking. Now can we go to yellow G 5, yellow Golf 5.
LH: I don't have to let him past I should be able to take that position back, if he made a mistake.
Team: Yes, we understand Lewis. Let's just do it by the book. We are asking Charlie now. You are in P4. If you hold this position. Just keep it together.
Team: OK Lewis, your KERS is full, your KERS is full. Just be aware. You can go back to black F2, black Foxtrot 2.
LH: Any news from Charlie whether I can take it back or not.
Team: Still waiting on a response Lewis, still waiting.
Team: Lewis, work on your brakes please. Front brakes are cold.
Team: If we are able to use one KERS that would be good. If you deploy KERS please do so now.
Team: OK, Lewis, this is the last lap of the race. At the end of the lap the safety car will come in, you just proceed over the line without overtaking, without overtaking. We are looking into the Trulli thing, but just hold position.
To listen to a recording of the radio transmission between Lewis Hamilton and the team, click here.
in pratica il pilota maclaren viene penalizzato per avere seguito l'indicazione della squadra a rispettare il regolamento per evitare episodi simili a quelli di spa...all'epoca era stato penalizzato per avere sorpassato senza rendere la posizione nei "modi dovuti", questa volta per averla "restituita"...insomma è comunque "colpevole"
LH: OK.
è stao il comportamento apertamente scorretto: ha rallentato vistosamente accostando sul lato come se avesse avuto un ictus cerebrale! inducendo in tranello chi lo seguiva perchè sembrava si stesse ritirando!!!!!!!!!!!!!!!!!!!!!
e certo, in questo casino ci sono i cattvoni della Ferrari....
Per (il solito) Acle:
mi sa che ti sei perso il Mondiale 2007, o te lo sei semplicemente dimenticato...
caro viscatto, quando si fanno certe affermazioni...bisognerebbe prima riflettere...
ma dato che era già in 3 a posizione che motivo aveva di rallentare per far passare Trulli, se non quello di restituire la posizione a norma di regolamento per evitare quello che era accaduto a Spa?
caro mafalda, stiamo parlando della FIA....
lascia da parte gli altri episodi che con questo non hanno nulla a che vedere
ecco bravo: la Ferrari non ha nulla a che vedere che questa controversia.
Inoltre le prime reazioni della mcLaren sembrano più blande di quelle di alcuni forumisti...
LH: OK.
no. il problema è un altro. trulli ha dichiarato di averlo superato perchè praticamente hamilton era fermo,ma sia lui che la squadra hanno negato. quindi sono stati penalizzati perchè mentendo hanno tratto vantaggio vedendo penalizzato l'incolpevole jarno.ciao.
ma tu credi veramente che le cose sarebbero diverse con appelli e fregnacce varie?
caro scamorza, hamilton stava restituendo la posizione su indicazione del box...per evitare situazioni come quella di spa....in quel caso penalizzato per non averla restituita nei modi dovuti...in questo caso per averla restituita...ma non ti pare assurdo
Senti: hai deciso che dietro c'è la Ferrari? libero di crederci
ma allora vuoi litigare...ma dove hai letto quello che dici? si stava parlando della FIA e delle sue decisioni assurde....chiaro? o devo ripeterlo...la FIA e le sue mignottate
non l'avrà letto, ma ormai conosciamo i nostri polli, e tu sei dichiaratamente antiferrarista :D
sulle mignottate FIA mi troverai sempre concorde. ma ribadisco l concetto del mio primo post qui: non mettere in mezzo al Ferrari quando non c'entra proprio nulla :D
Guide
  • Dossier Auto Usate
  • Problemi con l'auto
  • Revisione
  • Patenti Speciali
