<img height="1" width="1" style="display:none" src="https://www.facebook.com/tr?id=1500520490268011&amp;ev=PageView&amp;noscript=1"> Winch Cause Overheating | Il Forum di Quattroruote
The main reason for a winch overheating is because it is not getting enough airflow to reduce heating it. The best way to fix this is to open up the hood and remove any obstructions blocking the airflow.
You can also use a fan to help move air around the winch. Lastly, you can install a heatsink or Fan controller to help reduce overall heating.
You can check more about winches at Heavy Duty Guide.
al.set
