Skoda GreenLine second generation:
- New engine 1.2 TDI CR DPF/55 kW
- Start-Stop system. Benefits of Start-Stop is most evident when driving in city traffic. The system switches on automatically when you start the engine and the driver if the vehicle after some time driving stops, put into neutral and release the clutch pedal, the engine switches itself off. Once the driver presses the clutch, the engine starts up again immediately. This way you can save in mixed mode, 0.2 to 0.4 l/100 km in city traffic then even 0.3 to 0.9 liters of fuel 100 km.
- Brake Energy Regeneration is another element of modern technology, which are the Fabia Combi GreenLine and Roomster GreenLine suite. Efficient use of kinetic energy to recharge the car battery is a simple system that helps save fuel continuously in small doses.
- Gear recommendation, which helps the driver optimally exploit the potential of the engine,
- Further reducing aerodynamic and chassis cover
- Tires with low rolling resistance
http://translate.google.it/translat...0_37_Greenline_II_generace.aspx&sl=auto&tl=en
Direi che finalmente ha un senso chiamarla Greenline.
Tutta una serie di interventi che alla fine dovrebbero portare un risultato apprezzabile nella riduzione dei consumi.
I dati dichiarati sono:
3.4 l/100 km and CO2 emissions just 89 g / km for the Fabia Combi GreenLine,
4.2 l/100 km and CO2 109 g / km for the Roomster model GreenLine
