<img height="1" width="1" style="display:none" src="https://www.facebook.com/tr?id=1500520490268011&amp;ev=PageView&amp;noscript=1"> Eccolo! DQ500 | Il Forum di Quattroruote
Eccolo! DQ500
Come vi avevo già anticipato, nella fabbrica di Kassel è nato il bimbo nuovo.
DQ500 7 marce doppia-frizione trasversale da 600Nm anche per trazioni integrali.
In 2009, six years after launching the first DSG® dual clutch gearbox in the world, Volkswagen presented a new member of the extremely successful DSG® family. These gearboxes represent a unique synthesis of comfort, sportiness and fuel efficiency. Building on the experiences afforded by the proven DQ200 and DQ250 gearboxes, the new DQ500 now makes dual clutch technology available to customers with larger and high-performance vehicles. The DQ500 is currently the world?s only seven-speed transverse-mounted gearbox for high torques that is in large-scale series production. The clutch is designed for an engine torque of up to 600 Nm, and yet 8 mm smaller than in the DQ250. It can be used for a range of applications from sporty passenger cars to commercial vehicles.
The transmission world is still dominated by manual transmissions in Europe and conventional automatic transmissions in the USA and Japan. Both concepts have their benefits: Manual gearboxes are robust and feature low prices and a high efficiency. Drivers also value their driving pleasure and sportiness. Conventional automatic transmissions are above all comfortable. Shifting gears without interruption in tractive force offers a unique driving experience. The Volkswagen dual clutch gearbox combines the best of both worlds.
Automatic transmission enthusiasts leave gear selection to the sophisticated driving programs while sporty drivers enjoy the sequential, manual gear shifting. As to fuel consumption, DSG® dual clutch transmissions are as efficient as manual transmissions and, depending on the engine type, fuel consumption may even be lower.
Like the dual clutch installed in the DQ250, the dual clutch of the DQ500 also consists of two concentric, ?wet? individual clutches. Their main task is to transmit engine torque and to shift gears in the sub-transmissions. In addition, they allow for comfortable acceleration from standstill in the first gear (outer clutch) and in reverse gear (inner clutch). Clutch 1 is the outer clutch which shifts the gears 1 ? 3 ? 5 ? 7. Clutch 2 is the inner clutch which shifts the gears 2 ? 4 ? 6 ? R. In contrast to the DQ250, clutch 2 is thus also used to accelerate from standstill in reverse gear. Arranging the gears 1 and R in the separate sub-transmissions allows for quick changes of direction when maneuvering simply by acting on the dual clutch.
enlargeIntricate mechanical and time-related processes set high demands to the entire control system of the DQ500. The software - developed in-house at Volkswagen - plays a decisive role in achieving the precision and comfort of the new gearbox. These complex processes are almost not perceptible by the drivers - even if they manually intervene in gear selection.
While previously existing DSG® gearboxes have been installed in vehicles of the A0, A and B classes, the DQ500 will see its premiere in the new generation of the Transporter and Multivan. The new DSG® gearbox is ideally suited for this vehicle class and offers a unique driving experience within its competitive environment. The 7th gear has been designed as an overdrive, which has a positive effect on consumption especially in customer-oriented longdistance journeys. In combination with the completely new, two-stage turbocharger 2.0 l biturbo TDI engine which has also been optimized with regard to its consumption, the DQ500 allows for fuel economy to be improved by 1.6 l/100 km compared to the predecessor drive configuration.
Its suitability for four-wheel drives, high engine torques and sporty concepts emphasizes that this DSG® will, like the other DSG® gearboxes, play a major role in Volkswagen?s module system. This gearbox marks the extension of Volkswagen?s DSG® strategy to include high-performance confi gurations and further strengthens its market position in the fi eld of dual clutch gearboxes. DSG® technology thus contributes to the reduction of fuel consumption and emissions also in higher vehicle classes now.
http://www.volkswagenag.com/vwag/vwcorp/info_center/en/themes/2010/01/dsg_the_new_dq500.-bin.acq/qual-InfoDetail.Single.Imagezoom1/_Titelbild_Schnittkupplung_zoom.jpg
http://www.volkswagenag.com/vwag/vwcorp/info_center/en/themes/2010/01/dsg_the_new_dq500.-bin.acq/qual-InfoDetail.Single.Imagezoom2/Kraftverlauf_en_zoom.jpg
008CTAVIA
bene, ora non basta che aspettare la Skoda Octavia 2011 RS 2.0 biturbo diesel 204 cv 4motion DSG 7 marce.
che dire....io sarei il primo a prenderla!!!!!!
venisse fuori davvero staccherei immediatamente l'assegno per essere il primo ad averla :lol: :cry:
peccato non avere eurini da spendere :p
Cmq interessante che finalmente vi sia anche x Skoda il 7 marce abbinabile alla trazione integrale...che abbinamento favoloso signori!
Devo dire che rispetto al layout del DQ250 (cioè quello che montata la TT 4X4) aggiungere il 4X4 al DQ500 prevede un coperchio lato frizione (seconda figura) completamente diverso....boh! A prima vista non sembrerebbe nato per il 4X4.
Però in VW ovviamente sanno quello che fanno.
Adesso non vorrei esagerare. Sapete che sono un fan del DSG.
Ma in questo campo VW è troppo avanti. Non esiste concorrenza degna di questo nome quando hai un cambio trasversale, sette marce, da 600Nm, con possibilità di montare anche il rinvio per il 4X4 Haldex.
L'unica cosa su cui mi sembra di poter dire esiste qualcuno un po' più avanti (bisogna vedere con che affidaiblità) è Getrag che nel DSG6 frizioni a secco invece di usare attuatori idraulici (con relativo circuito) usa quelli elettrici (in teoria dovrebbero assorbire meno energia).
Powershift 6DCT250 che dovrebbe finire su Ford, Volvo e Renault però è 6 marce.
Tutto il resto è vuoto totale in questa fascia di prezzo/prestazioni.
Quella sarebbe la macchina perfetta... anche se ho la sensazione che questo aggeggio in Skoda lo vedremo nel 2050... :lol:
Anche perché ora non sfondiamo i 350 Nm del 2.0 TDI-CR 170 CV e del 3.6 V6 FSI 260 CV...
Credo che in Skoda lo vedremo entro la fine dell'anno, ma non ho capito se il DQ250 (col 4X4) o il 500 (effettivamente mi sembra un po' esagerato per lo Yeti col 170CV).
I motori VW 2.0 arrivano già a 400Nm (un po' pochi rispetto ai 500Nm della concorrenza)....
Lo stesso motore che indichi tu... cioè il 2.0 TDI-CR 170 CV c'è già in queste due versioni:
132 kilowatts (179 PS; 177 bhp) @ 4,000 rpm; 400 newton metres (295 ft·lbf) @ 1,500-2,000 rpm ? Volkswagen Transporter (T5) GP Biturbo
147 kilowatts (200 PS; 197 bhp) @ 4,400 rpm; 400 newton metres (295 ft·lbf) @ 2,500-3,000 rpm
la seconda versione è singolo turbo, ma mi sembra strano di vederlo montato su un mezzo con ruote, avendo la coppia fra i 2500 e i 3000, forse ha qualche uso industriale.
Sono un felicissimo possessore di octavia 1.9tdi DSG con la quale in due anni ho percorso 105.000km con (fino ad ora) nessun problema..(speriamo....)
sapete indicarmi su quali motori sarà montato il DSG cn il 4x4 e quando sarà preivisto per l'italia???'
Grazie in anticipo per le vostre risposte.
Grazie, ora mi è più chiaro ;)
Già che parliamo di probabilità, che probabilità ci sono di un'Octavia 2.0 TDI-CR 170 CV AWD o comunque di una AWD berlina? Grazie :)
ciao! io me lo aspetterei con i motori più potenti.. diciamo dal tdi 140 cv in su...
Agus posso dirti che mi hai rotto le OO? :D sai sempre tutto! Sei fantastico, un'autenticxa miniera di informazioni! 5 stellette!
Agus la presenza di un singolo turbo e la coppia alta credo sia sintomo di turbina grossa e quindi allungo.. forse è una cosa voluta.. per i motori industrriali adottano ben altre potenze specifiche. il fatto dei "soli" 400 Nm è voluto anche quello sennò sbriciolano gli attuali cambi montati sulle auto di gamma medio-bassa, lo fanno un po' tutti, anche BMW sulle serie 1.. limitano con la centralina la coppia erogata dal motore... non chiedermi come fanno perchè non lo so.. so solo che anche le Mercedes 65AMG adottano questo stratagemma per tenere la coppia sotto i 1000Nm :shock: sennò il motore ne erogherebbe 1200 e frullerebbe il cambio :shock: :shock: :shock:
Questo forum senza te non sarebbe lo stesso :!: 5 stelle ad Agus. Aspetto anch'io il dsg sull'integrale per farci un pensierino...ma posso attendere.
p.s. come mai io ne ho (indegnamente) 4 di stelline e tu (ingiustamente) le stesse?
perchè qualche simpaticone attribuisce ad Agus una sola stellina e quindi 4R fa la media... ciò significa che nonostante noi diamo a lui una caterba di 5 stelle altri zuzzurelloni gliene danno 1 quasi altrettante volte
