@gnpb et voilà: questo è l'output che mi ha dato PRIMA della sostituzione della batteria. Ho lasciato solo le parti relative agli errori, io non ci ho capito nulla però...
Friday,10,April,2020,14:29:08:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
VIN: xxxxxxxxxxxxxxx License Plate: PRIMO TEST
Mileage: 43943km-27304mi Repair Order:
Chassis Type: AU (5Q0)
Scan: xxxxxx
VIN: xxxxxxxxxxxxxxxx Mileage: 43943km-27304miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CXSA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 DE HW: 04E 907 309 A
Component: 1.4l R4 TSI H08 5672
Revision: WAH08---
Coding: 01190032234405082000
Shop #: WSC 00028 028 00075
ASAM Dataset: EV_ECM14TFS01104E906016DE 002002
ROD: EV_ECM14TFS01104E906016DE_VW37.rod
VCID: 68D863E293E89B0141-803C
2 Faults Found:
7158 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 43943 km
Date: 2020.04.10
Time: 14:22:02
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 16 °C
Intake air temperature: 16 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.874 V
Unlearning counter according OBD: 40
Generator: load signal: 99.89 %
Generator power: 0 W
Torque request: sum of auxiliary aggregate: 30.3 Nm
Status of starter activation-Bit 0: 0
5583 - Oil Pressure Switch for reduced Oil Pressure
P164C 00 [036] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 43943 km
Date: 2020.03.19
Time: 16:50:33
Coolant temperature: 14 °C
Intake air temperature: 15 °C
Voltage terminal 30: 11.756 V
Mass flow through throttle valve: 0.0 kg/h
Median injection timing: 2.818 ms
Engine operating condition: Idling
Engine operating condition-Test_Program_Channel 87: 5
Readiness: 0000 0000
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A
Component: ACC Bosch MQB H04 0150
Serial number: 29029876510386
Coding: 00000100FE0339
Shop #: WSC 00028 028 00207
ASAM Dataset: EV_ACCMRRBoschVW372 001013
ROD: EV_ACCMRRBoschVW372_VW26.rod
VCID: 3566FA9694DA36E90A-8060
1 Fault Found:
1127 - Databus
U1122 00 [008] - Implausible Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 43943 km
Date: 2020.03.19
Time: 16:50:19
Control Module temperature: 15 °C
Voltage terminal 15: 10.3 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 M
Component: GW MQB High 212 2147
Revision: -------- Serial number: 28034210834203
Coding: 030100042B086400EF000058080F00010001000000000000000000000000
Shop #: WSC 00028 028 00023
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti_009.rod
VCID: 3B72ECAEB2FEE099FC-806E
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H14 0035
Serial number: 271331931342093334
Coding: 2CFFFF
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 34033667903
1 Fault Found:
197149 - Generator
U1052 00 [009] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 215
Mileage: 43943 km
Date: 2020.04.10
Time: 14:21:59
Supply voltage: Terminal 30: 11.8 V
Terminal 15: On
