<img height="1" width="1" style="display:none" src="https://www.facebook.com/tr?id=1500520490268011&amp;ev=PageView&amp;noscript=1"> DIFETTO SKODA RAPID MOTORE TDI CR 1.6 105 CV | Il Forum di Quattroruote
vOGLIO SEGNALARE UN DIFETTO RISCONTRATO SULLA MIA NUOVA SKODA RAPID SPACEBACK 1.6 TDI 105 CV AMBITION. MI SONO RIVOLTO ALL'ASSISTENZA UFFICIALE DELLA MIA ZONA PER ORDINARE IL COPERCHIO PARAMOTORE IN PLASTICA (INCREDIBILE CHE SIA UN OPTIONAL). IL MECCANICO OSSERVANDO IL MOTORE SI E' ACCORTO CHE IL TUBO CHE PORTA IL LIQUIDO DI RAFFREDDAMENTO DALLA VASCHETTA DI ESPANSIONE AL RADIATORE PASSANDO MOLTO BASSO ENTRA IN CONTATTO CON LA CINGHIA CHE A LUNGO ANDARE POTREBBE CONSUMARLO E FORARLO CON LE OVVIE CONSEGUENZE. ABBIAMO RISOLTO SEMPLICEMENTE CON UNA FASCETTA COLLEGATA AL TUBO SUPERIORE DEL MOTORE. LO SEGNALERO' AL CONCESSIONARIO PER FARE IN MODO CHE ALTRI POSSESSORI NON ABBIANO LO STESSO PROBLEMA CHE HO SCOPERTO PER PURO CASO E FORTUNA.
