<img height="1" width="1" style="display:none" src="https://www.facebook.com/tr?id=1500520490268011&amp;ev=PageView&amp;noscript=1"> Volvo Car Corporation launches automatic DRIVe diesels | Il Forum di Quattroruote
Volvo Car Corporation launches automatic DRIVe diesels with the same fuel consumption as manual versions
Volvo Car Corporation is already in the lead among European carmakers when it comes to reducing carbon dioxide emissions - and the journey continues with two new CO2 cutting initiatives:
The 1.6-litre diesel combined with automatic Powershift gearbox now comes with the same low fuel consumption and CO2 levels as the manual DRIVe versions.
At the same time, CO2 emissions from the turbocharged, 1.6-litre T3 petrol engine with manual gearbox are down to 139 g/km.
The new possibility to combine the four-cylinder, 1.6-litre diesel engine (115 hp) with the six-speed Powershift gearbox is available in four models: Volvo S60, V60, V70 and S80.
"For the first time ever, we have managed to bring the fuel consumption in variants with automatic gearbox down to the same level as in the manual versions. An impressive achievement by our powertrain experts," says Peter Mertens, Senior Vice President Research and Development at the Volvo Car Corporation.
Fuel consumption in the Volvo S60 with the 1.6D engine and Powershift is 4.3 l/100km. This translates into CO2 emissions at 114 g/km. The corresponding figures for the Volvo V60, V70 and S80 with the same engine and gearbox are 4.5 l/100 km and 119 g/km.
The low consumption and emission levels are the result of a number of technological improvements:
Friction between gearbox components has been reduced.
The engine and gearbox software have been modified.
The start/stop system cuts off the diesel engine when the car is still rolling (below 5 km/h).
All electrical systems have been optimised to create lower energy consumption.
Petrol powered T3 under 140 g/km
Volvo Car Corporation's DRIVe Towards Zero also includes improvements of the petrol engines.
By optimising the four-cylinder, 1.6-litre T3 engine (150 hp), which is available in the Volvo S60 and V60, the engine experts have managed to bring fuel consumption down do 5.8 l/100 km in the S60. This corresponds to CO2 emissions at 135 g/km.
The figures for the direct-injected T3 engine combined with automatic Powershift in a Volvo S60 are 7.1 l/100 km and 164 g/km.
"Keeping the CO2 emissions below 140 grams is essential since this is a level used by many fleet customers. We have managed to do this in the T3 version through a number of small, significant improvements. We have also optimised the gearbox gearing for maximum fuel efficiency without loosing the engine characteristics," says Peter Mertens.
European leader in CO2 reduction
Volvo Car Corporation leading position among European carmakers when it comes to reducing carbon dioxide emissions is shown in the annual analysis presented by the European Federation for Transport and Environment (T&E).
Volvo Car Corporation outperformed Europe's eight largest car manufacturers in 2010 by cutting overall CO2 emissions with no less than 9 percent.
"This excellent result is the outcome of a dedicated environmental focus under our "DRIVe Towards Zero" banner. One third of our research budget is earmarked for reducing CO2 emissions. Our new, upcoming Volvo Environmental Architecture engine range, which consists solely of four-cylinder engines, will ensure that we continue to beat our toughest competitors when it comes to fuel economy," says Peter Mertens.
abarbolini ha scritto:
Ma il mitico Smargia sa per caso quando entrerà effettivamente a listino in Italia?
Grazie per il mitico.
Di fatto non è arrivato nulla di nulla, anche se credo che le prime novità a livello di powertrain si inizieranno a vedere con l'uscita della V30, quindi già a Ginevra (marzo) si dovrebbe avere qualcosa di ufficiale, almeno a livello di notizie o comunicati stampa.
Quindi in pratica vuol dire MY13?
Spesso, a seconda dei modelli, i model year sono di diverso tipo anche el corso dello stesso anno, nel senso che in un determinato anno (ad esempio il 2012) ci può essere che so, una V70 che ha model year 2012 e una S80 che è già al 2013.
Non vengono aggiornati tutti contemporaneamente per tutti i modelli.
Penso (mia personalissima opinione) che il 1.6 D con l'automatico possa uscire ( almeno presentato) in occasione del debutto ufficiale della nuova car line, che come ripeto, dovrebbe esordire a Marzo a Ginevra, fare il primo ingresso nelle concessionarie prima dell'estate e iniziare il grosso delle consegne (sia la berlina che la cross country) a partire da ginevra.
Questo non toglie che, visto che sia il motore che il cambio non costituiscono, se presi separatamente, una novità, e visto che si parla nell'articolo, esplicitamente delle altre car line (con particolare riferimento alle S/V60) e visto che tra marzo e settembre ci corre un semestre buono buono, in quest'arco di tempo non pesano venire commercializzate anche altre auto con il 1.6 D e il doppia frizione.
Escluderei solo S40 e V50, oramai giunte alla fine del loro percorso.
Questo è sicuro. Il comunicato stampa parla esplicitamente di S/V60, V70 e S80 e non fa alcun riferimenti a S40 e V50.
Comunque è ufficiale. Usciranno a primavera (immagino verso aprile/maggio) su S60 e V60
Altra novità è una versione depotenziata del 2.0 D 5 cilindri con potenza di 136 CV su S/V60 V70 e S80.
Spero che ciò porti per la V70 ad una rimodulazione dei listini perchè c'è poco spazio tra la Drive e D3 (meno di 2000 Euro). Ovviamente spero in basso...
P.S. chissà poi perchè in S/V60 ci sono più di 3000 euro tra Drive e D3 mentre ce ne sono meno di 2000 su V70?
questo fa quindi tramontare ogni speranza di vedere il 1600 in versione più potente? la gamma sarà 1600 115cv, 2000 136 cv e avanti cosi? e stessa cosa per la futura v30 (o come si chiamerà)?
Non lo so io penso (forse solo spero) che sui motori a breve ci sarà qualche rimodulazione della gamma.
Di fatto va a sparire il 2.0 4 cilindri, il 1.6 penso che prima o poi (magari in occasione della V30) dovrebbe essere rinfrescato e qualche novità penso che sia logico aspettarsela anche dal 5 cilindri, magari con l'introduzione della doppia sovralimentazione sul 2.0 (non dimentichiamo che di fatto questo motore è uscito appena un anno fa e già al suo esordio e in versione monoverbo è arrivato a 177 CV) e a questo punto un ulteriore aumento di potenza per il D5 2.4
Poi c'è il capitolo ibrido in cui Volvo pare voler credere molto, in accoppiata al diesel, il tutto in attesa dei nuovi motori che dovranno essere sviluppati in seguito alla cessazione dei rapporti con Ford.
Non dimentichiamoci che attualmente tutti i motori a 4 cilindri sono frutto dei precedenti accordi con Ford, bisognerebbe capire cosa prevede nel dettaglio l'accordo di vendita a Geely.
Ma esiste una s80 millessei? :shock:
A listino esiste. In pratica non ne ho mai vista una.
Se poi parliamo di benzina il T4 da 180cv è anche quello un 1600.
Per carità magari salterà fuori pure una A6 Audi col 105 hp 1,6 o una BMW 516...
E la volvo era solo più avanti di loro....
Economie virtuali secondo me...no?
