LEXUS 2013 RX450H NEW CAR FEATURES
AUDIO / VISUAL / TELEMATICS
Audio & Visual System
2. MAJOR DIFFERENCE
(a) The 2013 models have been modified from the 2012 models as shown below:
(1) The design of the following items in the combination meter assembly has been changed:
? Indicator and warning light layout
? Hybrid System Indicator
? LCD (ODO/TRIP display and shift position indicator)
(2) A function that changes meter panel illumination color in accordance with the vehicle driving conditions has been added.
(3) The following functions that can be enabled or disabled in the electronic features control mode of the multi-information display have been changed:
? Sport Mode Switch: Added
? AFS ON/OFF Switch: Discontinued
? EV Mode Switch: Discontinued
(4) Blind spot monitor system related warning messages have been added to the warning messages displayed on the multi-information display.
(5) The text of the warning messages for the maintenance required reminder function, which are displayed on the multi-information display, has been changed.
(6) The display design of the headup display has been changed
Lexus Enform System
2. MAJOR DIFFERENCE
(1) The display and navigation module display has been combined with the radio receiver assembly, becoming integrated into the multi-media module receiver assembly.
(2) Due to the adoption of a new type HDD navigation system, the Apps service has been added to the LEXUS ENFORM.
Safety Connect System
2. MAJOR DIFFERENCE
(1) The safety connect system has been adopted on models with the Lexus display audio system.
(2) The display and navigation module display has been combined with the radio receiver assembly, becoming integrated into the multi-media module receiver assembly.
Garage Door Opener
2. MAJOR DIFFERENCE
(1) The location of the garage door opener switch has been changed to the area on the inner rear view mirror assembly.
Navigation System / Multi Information Display
2. MAJOR DIFFERENCE
(1) The DVD type navigation system has been discontinued.
(2) A new model HDD navigation system is available.
(3) The display and navigation module display has been discontinued. Instead, the multi-media module receiver assembly, which integrates the navigation ECU and radio receiver assembly, is provided
Blind Spot Monitor System
2. MAJOR DIFFERENCE
(1) The blind spot monitor system is available.
Intuitive Parking Assist System
2. MAJOR DIFFERENCE
(1) 2 front No. 1 ultrasonic sensors have been added on the front center portion of the vehicle, expanding the detection area of the intuitive parking assist system.
(b) The screen, which appears on the multi-information display and/or multi-display* when the intuitive parking assist system detects an object, has been changed.
*: Models with Lexus display audio system, 12-speaker surround sound system, 15-speaker surround sound system or HDD navigation system
Monitor System
2. MAJOR DIFFERENCE
(1) A monitor system has been adopted on the Lexus display audio system.
(2) The side monitor system has been discontinued.
Parking Assist Monitor System
2. MAJOR DIFFERENCE
(1) The side parking assist monitor system has been discontinued.
(2) The parking assist ECU has been integrated in the multi-media module receiver assembly.
(3) The parking assist monitor system is controlled by the multi-media module receiver assembly.
(4) The screen displayed for the parking assist monitor system has been changed.
BRAKE
Brake (Front) -- No changes
Brake (Rear) -- No changes
Brake Control System
2. MAJOR DIFFERENCE
(1) The brake pedal stroke sensor has been changed to a non-contact (semiconductor) type.
DRIVETRAIN -- No changes
Parking Break -- No changes
Axle System - No changes
Drive Shaft System - No changes
Hybrid Transaxle System - No changes
Rear Drive System - No changes
ENGINE / HYBRID / EV SYSTEM
Cooling System - No changes
Emission Control System - No changes
SFI System - No changes
Engine Unit - No changes
Fuel System - No changes
Exhaust System - No changes
Intake System - No changes
Lubrication System - No changes
Cruise Control System
2. MAJOR DIFFERENCE
(1) The warning indication on the combination meter assembly when a malfunction is detected in the cruise control system has been changed.
Dynamic Radar Cruise Control
2. MAJOR DIFFERENCE
Hybrid Control System
2. MAJOR DIFFERENCE
(1) Due to the adoption of the EV drive mode switch, the operation to enter EV drive mode has been changed.
(2) SPORT mode control is provided. This control increases the drive force provided by the vehicle during mid-range acceleration, enhancing acceleration response.
(3) An additional operation method of the emergency shutdown function has been provided, which stops the hybrid system when holding the power switch for approximately 2 seconds or the power switch is pushed 3 times or more in a row.
(4) The inverter water pump assembly has been changed.
POWER SOURCE / NETWORK
CAN Communication System
2. MAJOR DIFFERENCE
(1) The side parking assist monitor system has been discontinued, resulting in the parking assist ECU being discontinued from CAN communication system.
(2) The blind spot monitor system has been adopted, resulting in the blind monitor sensor added to CAN communication system.
LIN Communication System
2. MAJOR DIFFERENCE
(1) The automatic high beam system has been discontinued, resulting in the inner rear view mirror being discontinued from LIN communication
Multiplex Communication System
2. MAJOR DIFFERENCE
(3) In accordance with the change of navigation system and audio system, AVC-LAN communication system has been changed.
(4) The automatic high beam system has been discontinued, resulting in the inner rear view mirror being discontinued from LIN communication system.
Electric Power Control System - No changes
STEERING
Power Steering System - No changes
Heated Steering Wheel System
2. MAJOR DIFFERENCE
(1) he heated steering wheel system has been adopted
Steering Column System - No changes
Steering Lock System - No changes
SUSPENSION
Front Suspension System - No changes
Rear Suspension System - No changes
Tire and Wheel Type System
2. MAJOR DIFFERENCE
(1) Newly designed and painted wheels are available on specified models.
Tire Pressure Warning System - No changes
VEHICLE EXTERIOR
Fuel Lid Opener System - No changes
Power Back Door System
2. MAJOR DIFFERENCE
(1) The door lock request can be accepted and reserved while the back door is closing, improving usability of door lock operation.
Body Structure
2. MAJOR DIFFERENCE
(1) The design of the front headlights, front bumper cover, and upper and lower radiator grilles has been changed.
(2) An aero stabilizing fin is provided to enhanced aerodynamics.
(3) Performance dampers (front and rear) have been adopted for F SPORT.
Lighting System
2. MAJOR DIFFERENCE
(1) The exterior light design has been changed.
(2) The intelligent Adaptive Front-lighting System (AFS) and automatic high beam system have been discontinued.
(3) The battery saving function has been added to prevent the auxiliary battery from discharging when the headlights or taillights are left on.
Mirror System
2. MAJOR DIFFERENCE
(1) The new model HDD navigation system is available.
(2) The operation screen for the front wiper deicer system has been changed due to the change of the navigation system.
(3) The Lexus display audio system has been added to the available audio system.
Towing Converter System - No changes
Sliding Roof System - No changes
Vehicle Proximity Notification
1. OUTLINE
(a) When the vehicle is being driven quietly using the motor only, the vehicle proximity notification system outputs a warning sound from the vehicle approaching speaker assembly to inform pedestrians, cyclists, etc., of the approach of the vehicle.
(b) The warning sound is output by the vehicle approaching speaker assembly at a volume level that will not be perceived as noise. Also the pitch of the sound changes in accordance with the vehicle speed so that the sound reflects vehicle deceleration and acceleration.
(c) Vehicle proximity notification system operation automatically stops when the vehicle is stopped, the engine starts or the vehicle is driven at 20 km/h (12 mph) or higher
2. MAJOR DIFFERENCE
(1) The vehicle proximity notification system has been adopted.
Power Window Control System - No changes
Windshield / Window Glass System
3. MAJOR DIFFERENCE
Wiper and Washer System - No changes
VEHICLE INTERIOR
Power Door Lock Control System - No changes
Heating / Air Conditioning System
2. MAJOR DIFFERENCE
(1) The design of the air conditioning control panel has been changed.
Lighting (Interior) System - No changes
Meter / Gauge System
2. MAJOR DIFFERENCE
(6) The display design of the headup display has been changed.
Power Outlet Socket System - No changes
Pre-Collision System - No changes
Climate Control Seat System - No changes
Power Seat Control System - No changes
Seat Assembly - No changes
Seat Heater System - No changes
Airbag System
2. MAJOR DIFFERENCE
(1) The record data item of the event date recorder (EDR) has been increased.
(2) The side airbag sensor (for center pillar) has been discontinued.
(3) The operating condition of the seat outer pretensioners has been changed.
(4) The design of the steering pad (driver side squib) has been changed.
Occupant Classification System - No changes
Engine Immobilizer System - No changes
Smart Access System
2. MAJOR DIFFERENCE
(1) The time setting of 20 minutes for the automatic power off function to operate when the power switch is on (ACC) has been added.
(2) An additional operation method of the emergency shutdown function has been provided, which stops the hybrid control system when the power switch is pressed 3 times or more in a row or pressed for 2 seconds or more.
(3) The duration of the door ajar warning buzzer and key left in vehicle warning buzzer have been changed to 5 seconds.
Theft Deterrent - No changes
